2x 4890 is on par with a 295 so better than any single card out there.
If you really don't need DX11 or Eyefinity etc. Then the second 4890 is tough to beat.
If you are willing to overclock the 5850 it will likely be faster anyway.
If you are willing to overclock.
Because they scale better in crossfire than the 4890 does.
That's the thing, you're going to need a major overclock (1ghz +) to come anywhere close to crossfire 4890 performance, regardless of microstutter (which doesn't seem to affect everyone).
Also how many people get those clocks and what exactly are they doing to get them? I think reading these forums gives a very, very skewed representation of overclocking as I honestly think for every person who claims they have an amazing overclock, there are at least ten other people who can't go above the standard 900mhz.
Finally, the 5850 clocking higher than the 5870 is most likely BS. Relatively speaking, it probably overclocks more than a 5870, but in terms of absolute overclocks I very much doubt it will go higher than a 5870 as they are essentially salvaged 5870 cores.
Personally though, I'd still go for a 5870/5850, definitely not for raw performance.
Sorry but I find that hard to believe, show some benchmarks.
From a generalised rule on thumb, a 4870x2 is about the same as a 5870.
A 4890 is 20% faster than a 4870?
And a 5770 is the same as a 4870
SO realistically a 5850 is going to be nowere near as much horsepower as Xfire 4890's.
Yes it has DX11 and powerplay but nothing else.
People are forgetting recently that DX11 is not everything, the 5***(minus the 5970) won't be able to hande DX11 very well anyway. So futureproofing doesn't work out too well.
And correct me if im wrong but the 5850 is just a chip that didn't make out life as a 5870 chip. So a 5950 will not always OC to a 5870 + level.
Also with the zalman cooler:
http://i28.photobucket.com/albums/c235/Snatch362/lilbetter.jpg
Along with voltage tuning (5850s come at a lower voltage) getting over 1ghz should not be an issue.
But does that apply to every 5850? I'd suspect otherwise.
http://www.guru3d.com/article/radeon-hd-5770-review-test/14
Remember that the latest drivers have moved 5770 crossfire performance further on than the old sets most reviewers used.
