Ok actually I lie, didnt look at it in that much depth, only checked out reviews. Just a question, whats the importance of the wPrime 32 and wPrime 1024, as I see those are the two that differentiate the most between the 430 and 520. Thanks
I would suggest that you look at 3 in particular
Sony Vaio E Series
HP Pavillion DV6
Acer 5740 or 5740G (the G is just under £700 but it has a nice GFX if you intend to play any games)
If these are not to your liking let me know and will have another look for you
EDIT: I forgot to add that the Sony can be configured so you can tweak the hardware to suit your requirements better if you so wish
