P4 2.4 Packard Bell Laptop (Screen not working/very very faint)
1 Dec 2004
S.Wales
Hi,
Iv been given a Packard bell laptop (cant remember the model of the top of my head) which has a faulty screen so it seems, you can hear the screen booting into the OS, but the screen is black, if you angle it to one side you can see whats being displayed but its very very faint and you have to squint in low light.
Im pretty sure iv also tried this with an external monitor aswel but couldnt get it to work.
What do you think it would be? I thought maybe the inverter but then I thought it should work on an external monitor if that were the case?
Any help appriciated.
Sounds like the backlight has failed - but an external display should still work fine - usually you do need to use the hotkeys tho to toggle an external display on/off - i.e. it will boot and detect another display but not output anything to it - even when posting unless the function keys have been used to switch between display output modes.
Also, just to clarify, if I test it on an external monitor later and it doesnt work, would this still suggest the inverter or something else?
Can anybody confirm this? I need to know before I order, unfortunatly I need to buy a new power supply aswel so cant really test on external monitor atm, but im sure when I checked about 3 months ago it didnt work on external, but on the laptop you could see faintly the OS booting up.
If you can see the display then its definately the back light thats gone.
It's more than likely the inverter, but could be the screen itself or the mainboard, or it could be the lid switch thats turns the display off. Somes times these are near the bottom edge of the screen looks like a small peice of plastic sticking up, or on some packard bells it was in the left hand side recess where the lid catch goes.
Hmm, so it doesnt really narrow things down :( so potentially I would have to buy the power supply (deffo) or either an inverter, backlight or switch.
I can confirm that it DOES work on an external monitor, does this make the investigation any easier?
inverter or backlight or switch
I found a power supply with a similar rating for one of my other laptops, and although it booked up I could hear a sort of "click....click....click....click" coming from the mainboard, deffo electrical, could this be the power supply not being the correct model?
