Out of interest, anybody with an Intel X25 80gb that can tell me what the actual capacity is once formatted with NTFS?
AHCI, I use it at the moment, I was planning on continuing to use it with the SSD. That's correct?
74.4 GB
Yes - that's what I'm using.
You can create a bootdisc for Acronis which runs in it's own dos environment, which means the windows version is a mute point.Slightly OT, but it is to do with SSDs.....
Do any of you use Acronis True Image Home 2010 back-up and recovery?
I think I'm going to bite the bullet and go for the Intel 80gb drive today, but I just noticed that a competitor is selling the above software for £18, this week only.
As I said above, I have v10, but don't think this will work with Windows 7, and not sure about SSD.
So can anybody confirm that Acronis True Image Home 2010 definitely works with Windows 7 on a Solid State Drive?
I don't want to buy it if it isn't going to work, but wouldn't want to miss out if it does!
Thanks again for your replies,
Vin.
No problems here.
So, the Intel drive has just arrived. (Gotta love OcUK prompt delivery, I even loved that the courier tracking page listed approx what time he'd be here... and was)
Anyway....
Just stuck it in temporarily, using bluetack!
Will just do that until I've sorted it, installed Windows, and moved important files from my Raptor over to the SSD, and then the SSD can take the place of the Raptor.
Despite the box saying it was packed on 26th December '09, it appears to have an older firmware installed.
I've not even got as far as partitioning it yet... just literally connected it up, and booted into my Windows install on my Raptor drive, downloaded and installed the toolbox, and it shows my firmware as being 2CV102HA, whereas I believe the latest one is 2CV201HD. From the info on the site, it looks as though the HA firmware IS the Trim firmware, but the HD firmware has some enhancements, that it doesn't actually list.*
Oh well, I guess I may as well flash the firmware first, and then go to work installing Windows 7 on it.
Looking forward to trying this out
Vin.
EDIT: *
This firmware revision has several continuous improvement optimizations intended to provide the best possible user experience with the Intel SSD.
