recieving faulty items is part of the product experience, he should have waited until he got it replaced before reviewing so he could actually give some input on the product but mentioning he received a faulty one is useful info.
LOL, yeah, a poor product experience. Mentioning the fact that the product had to be returned is worth noting in the review.
It depends really on if the user returned it for a replacement (in which he should really wait and then review the (hopefully) working product, and can mention that it took two goes to get it right), or if that was the end of it and he returned it for a refund and tried a different product. In which case I would classify that as a legit review. You buy a product, it doesn't work as advertised and you return it and go for a different brand. Nothing wrong with making people aware that the product could arrive faulty.
But wouldn't you say receiving faulty items is in itself a 'review' of the product. I'll admit that it doesn't tell you about the functions of the product, and yes occasionally you have a faulty product here and there, but what if it's a common problem with that specific product.
For example, many people have had problems with a range of Seagate Barracuda hard drives and that it has a higher fail rate within the first month compared with other brands, myself being one of them, and this is a wide spread problem. Due to this experience, i no longer buy Seagate hard drives, but if other people were to read the reviews just saying that they are all fine and dandy, then they'll have no problem buying the product because they'll not know otherwise, but if they were to know that it has a higher chance of failing than other products, would they then not look for an alternative?
Its great to see more transparency on these reviews are handled
None of my reviews got published and there was no swearing in them at all just critical of ocuk .
What does ocuk have to do with the products though?
Or have they branched out into manufacture?
