My flat mate is in the market for a hot hatch and as started looking at the mk4 Golf R32s. His budget is up to 10k max so would be looking to get a 2003/4 example with around 60k on the clocks. My knowledge of these isn't great, other than I know they sound immense with a Milltek exhaust on them
, so thought I'd ask some questions.
His options are still open, so if the R32 is a no go what would you go for instead? His commute is a 25mile round trip and he wants a post 2002' hot hatch. As mentioned his max budget is 10k, but if he can do better for less then he could go down that route - for example my Facelift 2004 CTR was only £5800 with 54k on the clock, and that was the model with air con and in very good condition.
Many thanks
- Book mpg figures state 24mpg, how likely is this in the real world?
- These are 4wd, do they use the same Haldex system as the s3/TT?
- Whats the handling like? How connected to the car are you?
- Tuning, what are the options?
- What should he look out for? How reliable are they?
- What are the running costs like for these?
Many thanks
