Agree, the CF5770 comfortably beats the 4870 X2 2GB in all but one of the games in this review which I would think puts them at or near 4890 X2.![]()
You have to remember that the 5850 is effectivly underclocked and gets similar performance to a 5870 at the same speed.
Their cores tend to go further than 5870 cores too.
Wardogz, you've sparked WW3
Get a 4890 for a cheap and cheerful power boost![]()
But then why didnt you get another 4890 for a boost.![]()
got 3 of the same screen
Because AFAIK 4890 xfire won't give me eyefinitygot 3 of the same screen
Where oh where did you pull that little gem from?
http://forums.overclockers.co.uk/showpost.php?p=15942950&postcount=71
My xfire 4890 against 5850/5870
'the performance of a single 5770 is fairly poor'
As against a card twice the price do you mean ie 5850. Or against a card 3 times the price ie 5870 or against 260GTX, old tech and still more expensive. For around £110 I think anyone buying a 5770 should be very pleased with the performance. And as for two in crossfire, well beats 5850 and gets up to 5870 performance. Apparantly the 10.3 drivers are giving 5*** cards a huge boost in Dirt2, particularly in crossfire, so looking good for me.
See this thread.
Xtremesystems.
He does not have an HD 4890, this is a case of buying TWO HD 4890 or a HD 5850.
wow, im glad that's cleared up - rofl, thanks for all your replies, I can see it's a bit of a '6 of 1 and half a dozen of the other' situation. I'll just have to weigh up all the pro's and cons mentioned here and hope I decide correctly.
(except maybe the 5830 at it's current price lol)Am I reading here that the 5850 is much better value than the 5870?
5870:
1027 / 1286 @ 1.27v
5850:
1001 / 1232 @ 1.226v
On average 0.05V further to get 26mhz more..... It's certainly easier to get the 5850 to 1ghz levels and they perform very similarly when clocked the same.
http://www.xtremesystems.org/forums/showthread.php?p=4259395Just for reference a 5850 needs clocks of 940/1200 to beat a default 5870 in every aspect
