I am quite pleased with my comment on that video, childish, but hey ho!:
"I would like to plant my charge in your M-COM station."
Haha
I just liked the simple "I want to play with you"
I need some advice,
I have the following PC
x58 Extreme Gigabyte
920 @ 3.8ghz
6gb Ram
Xfi Extreme Music
1000w PSU
4870 1GB Gfx card
If I was to buy a 5850 will i be able to run BC2 full quality in settings at 1920x1200?
Thanks
Awesome.
This one is even better:
Karkand hasn't been confirmed yet has it? I know it was only a rumour....but can't find any confirmation unless anyone else can say otherwise?
No-one can truthfully answer because the beta wasn't optimised and didn't have all the high textures in, so there's no indication of how the performance will be at retail, if all goes well and it's optimised properly, then you will be able to yeah.
I need some advice,
920 @ 3.8ghz
6gb Ram
Xfi Extreme Music
1000w PSU
4870 1GB Gfx card
Thanks
Hmmm nice video's.... I'd....
I have the same specs almost, except I have a GTX 280 and my 920 is @ 4 GHZ.
At 1920 x 1200 with all settings maxed in game I suffer from frame rate droppages during combat. If I turn off horizon based ambient occulsion or whatever it's called (HBAO?) then I can play it fine- so with a 5850 then you'd be able to play it maxed easy.
Yeah, HBAO filters were majorly stuffed up in the beta, in retail they've fixed them apparently.
I couldn't actually see any difference with HBAO, any comparison pictures about? Normally I have a sharp eye when it comes to graphical differences but I couldn't ascertain it in the beta.
what does it do?
