Kay, I've been trying to sort out the temps in my antec 1200 to see if i can lessen them a bit, and I think 1 of the causes for it being higher may be too many fans (As crazy as it sounds)
Currently I have everything attached possible, I have the 3 front fans blowing in, the 2 back fans and 1 top fan as standard blowing out, then on my TRUE I have 2 fans in push/pull, and the 2 additional fans you can put in which are: 1 on the side of the case, and 1 infront of 1 of the front fans both blowing onto my GPU.
What kinda configuration is optimal for the case? Is there a few too many fans? (I don't mind about noise) and if there is, which should I remove?
Any advice welcome. Cheers.
