Just ran Dirt 2 at 1680x1050 max settings, forced DX9 and no AA, on a 5870 clocked at 5850 speeds and an i7 920 underclocked to 2.2 GHZ and two cores disabled. Results tell me the OP has got some major performance issues..
4890 results are very flawed, which makes me think the 5850 are too.
Just for comparision I was getting 55 fps in Crysis @ 1680x1050/High with my 5850. This was on a 3.4ghz Q9550, but since Crysis hardly uses multi-core processors, it's not going to make a huge difference.
Regardless of this though, a 4890 destroys a 8800GTX, so there's something wrong anyway.
Just face facts your results are screwed up, noway does a 5850 get that lower FPS in dirt 2, it's just about on par with a 8800GTX according to your results, it's crrrrrrrrrrrrazy...
Have you ever heard of a system bottleneck? I'm guessing it is my CPU because if I decrease resolution to 800x600 then the FPS increases to over 100FPS.
According to these results... 8800GTX SLI would run the 5850 hard sometimes beating it by a not insignificant amount.
But surely that indicates that you do not have CPU bottlekneck, because resolution affects only the GPU.![]()
WoW, you think it's that much of a difference between 1680 and 1920..do the math...![]()
17%, which can be quite a hit with AA
dlknight - good effort. Stacked graphs are a pain and wouldnt be the way to go without some data-fiddling. Clustered bars would be better and easier with excel![]()
Keeping the balance eh?
lol - not everyone has an agenda.
Agenda or not, you seem to have a habit of randomly posting irrelevant, unsubstantiated and poorly veiled pro-nvidia comments when ever the opportunity arises, yet whenever someone picks this up, you claim to have no agenda.
Clearly the OPs results are not consistent with many benchmarks posted elsewhere. For a start, the Crysis and Dirt 2 results don't seem to match up with my own.
It's not a huge deal, but what's the point in posting it on the forums if you know people will try to verify the results?
I hope your not being serious... if so you have severely mis-read me.
I said:
I'm not saying it DOES I'm saying that according to these result... I'm also not promoting nVidia over ATI at all in this case just observing that with SLI scaling if these results are correct the 8800GTX in SLI would still pack quite a punch (which it does anyway but thats another story).
