3DMark Vantage Score: 0??????
You need to run the software to get a score, that's probably the issue.
I did run the software. Went through two gpu tests two CPU tests and multiple feature tests and then I got a score of 0
could the reason be that I put on a custom red of 1920x1080 instead of the preset ones(performance, high etc. )
To get a score you cant modify any settings.
Has to be the default for entry, performances etc.
O ok thanks for the clarification. I'm re-running in performance mode since j couldn't do extreme. Or whatever it is.
Anyone know what the average gpu score for a 5850 is?
I can see, unlike the ignorant people of this world, that you've ran the software, but it seems like the software isn't giving you a total score :)
+ I have no idea why :) Try a re-install?
Wow haha, well your rig is clearly scoring higher than 0 , not to sure why the overall vantage scores doesn't seem to be working.
+1 for reinstall
Quick question for help.
I have the 5850 and a 8800GT Alpha Dog installed, and when getting to the Crash and Burn test it always crashes the with the Nvidia driver, and can never complete it.
Any hints guys?
It's coz your system is too suxz0rcopterz 4 Vantage.
Should've bought the 5890 mate! :(
dw by May I should have 2 x 5850's and a 8800GT in my system.
Soon after that, it's going to be an i7 920 D0 with the latest Asus 6GB/S Sata mobo and 1600Mhz 6GB RAM.
haha and once I get past the crash and burn test I'll show you I can get a score :p
OK guys,
Managed to do it, and now I'm confused, I think my score is quite low, but I'm not totally sure, should I be getting this on my setup?
How have you got that for your CPU? :confused:
Have you overclocked your 5850 at all? If not then the GPU score is about right. I did a thread on the same topic a couple of days ago. OCing to what's in my sig increased the GPU score to nearly 18000.
My CPU is just amazing :D haha na it's increased because my 8800GT is giving my 940 a big boost :)
and yes I haven't oc'd my gpu yet. I'm looking more to get my second 5850 for a little extra boost.
