Must resist buying speakers from 139sroberts in members market...![]()
Hey if they have been kicked off that many times and are still working, you know they will last
My surround sound setup is wall-mounted apart from the subwoofer, which is on the floor and much too heavy to be moved that way. My room is aligned to the speakers - chair first, so I'm in the right spot, then everything else to fit.
Although since I got neighbours I find that I use headphones instead. With my shift patterns, it would be unfair on the neighbours to use the speakers.
i kick my girlfriend off the computer thats about it.
it sometimes takes a good wallop in the face though, thats the only thing
Sounds like you have got an awesome setup![]()
Haven't used my speakers in a while now, i've got used to using headphones, and from time to time forgetting they're round my neck and getting up and yanking the cable out of the pc![]()
