Just knocked up a quick prototype and the result is I couldn't care!
Blackvault
You're a **** pete
Blackvault
Well, what about spinning a Zoopraxiscope at the speed of light, would you see anything?Which part of the propeller? Are you talking tip speed?
In order for the whole propeller area to be spinning faster than c, the tip speed would have to exceed c
so all places are moving at the speed of light...
What about the humans natural ability to see something move that fast?
Hmmmmm.What about the humans natural ability to see something move that fast?
They already move fast enough to seem near invisible.
I assume if you spun a propeller at the speed of light, it would fly away.
Ha ha, it'd take whatever its attached to as well.
That's another interesting question.
Would it actually give that much power if it was spinning so fast?
I suspect there is an optimum rpm for a propellor and it would be far less powerfull spinning at the speed of light.
Would it though?Either way, it'd make a great case fan.....
Would it though?
I dont think it would actually blow much air at all in fact.
Hmmmmm.
We can see light. Which usually moves at a speed close to c.
But that may be different? I dont know if you can see things which are moving at the speed of light.
Yeh light would get through. At a point in time, there will be light travelling through the gaps in the props, and light hitting the props. regardless of how fast they're spinning.
Maybe compare it to sound waves. propellor spinning at the speed of sound - can sound get through?
Also.... If the tips of the blades are spinning at the speed of light, then the centre of the propellor would be going slower, and stuff could definately get through... If the centre was going at the speed of light, then the tips would be exceeding it.. no? Which cant happen.
I reckon.
Doesn't matter at what speed it's moving at as long as it's in the humans eye refresh frame. We see at 60fps, so if it appears in one of those it could be seen.
Erm the whole thing would spin the same speed!! the edges of a circle do not spin faster than the centre if that was the case cd's wouldn't work
