I currently have a self-built watercooling system comprising of the following components :-
Laing D5 Vario Pump
EK Supreme Universal CPU Waterblock : Plexi
1/2 inch Materkleer tubing
Swiftech 2 x 120mm Radiator
XSPC single drive resevoir - clear
Feser one blue Cooling fluid
I shallnt bore you with current setup but what I want to do is expand this system on new PC build and want to know if it is feasable or pushing the limit for the pump and cooling.
New Build will include:-
NEW Gigabyte Gigabyte X58A-UD7 motherboard
Core i7 - 920 D0
ATI 5970 GPU with either EK FC5970 or Swiftech Epsilon HD5970 waterblock
So my current waterblock and system will work with the new CPU but I was wondering if I could also use it to cool
1) The gigabyte chipset through the included chipset cooling. I will need some 1/2 " to 3/8" reducers and a small amount of 3/8" pipe.
and
2) The ATI 5970 using probably 1/2" pipe to the inlet and outlet barbs on the waterblock. However maybe 3/8" to a full cover waterblock will suffice?
I believe I would need 4 Y Fittings to enable me to; slave 2 off the main line prior the CPU and 2 more to slave back into the main line prior to the radiator.
My main concerns are
a) The pump will have demand problems or fail much sooner (it is capable of 1200 ltr/hr though - an excellent pump I think).
b) It just wont be able to cool all of the components adequately (although it cools current Core2Duo E8700 , OC'd to 4.1Ghz easily).
I probably havent thought of everything so any advice and solutions are welcome. I dont however want to run a second cooling solution alongside my current one although I do realise that would provide the best results when overclocking.
Finally, I shallnt be overclocking the ATI5970 (well not just byet anyway) but I will OC the CoreI7-920 to at least 4Ghz.
Thanks in advance.
Laing D5 Vario Pump
Core i7 - 920 D0
and
Thanks in advance.
