ATI @ 120HTZ
2 Feb 2008
Rainham - Kent
Sorry if this has been posted before, but does anyone know how to stop the screen flickering @ 120htz with ATI overdrive clocking the gpu?. If I have the gpu @ default speeds the 2d desktop is fine:confused: but clocked it glitches:confused:
You can modify the bios and then you can clock it as much as the card will allow without problems.
A guide was posted not so long ago by Martini, try a search.
The Bios editor as well as any Bios can be found here . It's pretty easy to do and the flash itself only takes a second, but you will spend about 5 or 10 mins to get to that point.
Note:
All you need to do in the Bios Editor is change the 2d Memory clock from 300hz to 1200hz the GPU can remain the same.
You can also unlock the overclocking limits also.
