- 17 Apr 2007
- stat city
I am thinking of trying to overclock the 955 but would like to know what type of performance increase should I be expecting?
I hear the word 'luck'
Can I respectfully add to this question by asking would it be stable at 4GHz running 24/7 in a video crunching/editing computer? Or better left at, say, 3.8GHz?
Unless you get very lucky with your chip and have fairly awesome cooling I think 3.8GHz might be a bit more realistic for 24/7 use, the extra effort/voltage required for 4.0GHz most likely isn't worth the tiny performance boost.
Thanks. I'll try and get it to 3.8. Should I go up in increments or just jump straight to 3.8?
Processor: AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz
Motherboard: Asus M4A79XTD EVO
Case: Corsair Obsidian 800D Full Tower Case
CPU Cooler: Corsair H50-1 High-Performance CPU Watercooler
PSU: Corsair VX 550W ATX
Memory: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
I overclocked my amd to 3.8. My temps have went up from around 25-30 idle to 40-45 idle.
Went as high as 58 when playing bf2bc.
I thought the h50 was good enough for cooling.
his volts look about normal to me .
