Just brought Corsair Obsidian 800D
13 Feb 2004
stoke on trent
hi all
Just brought Corsair Obsidian 800D and just wondering if oc sell 6pin power cable extenders as mine are not long enought ?
yup NZXT 6 Pin PCI-E Black Sleeved 15cm Extension Cable spot on orderd two thanks for the speedy reply .this case is massive
so the power supply that came with it, the 6-pin PCI-E connecter wasnt long enough?
Sounds like the person who sold it to you stuck a PSU that doesnt belong in that case 2bh..
i have the 800d too its a right beast but my pcie cables were long enough, what psu are you using?
XFX case looks great and the new GPU is even better pics will be up soon just ordered pcie extension cables so for the mo i have them coming thought the water cooling holes at the bottom of the case .
The cable management is excellent but the sheer size of the case means that some cables can come up a little short. Had no problems with PCIe cables but have used more SATA cables than I would have liked with two power supplies now which is not a big deal. Just meant more clutter to cable tie behind the mobo.
Can't really fault the case. More an issue with PSU manufactures skimping on cable. Latest PSU, a Corsair HX1000W, has done well though. 6x SATA drives, sound card requiring floppy power (Xonar DX), and numerous molex powered fans only needed 3 modular cables in the end with a bit of planning / measuring before installation. If you have a modular supply you can always buy longer cables. Most manufactures recommend you use only their cables (or course) but provided you don't buy cheap crap I can't see any problem.
I've recently done a couple of builds for friends / family and used OCZ modular supplies, and had an OCZ non-modular myself until recently. All came with long cables, especially the PCIe. Length not the only issue. The spacing of the connectors can also be an important factor and again OCZ do well here.
as promised pics of new kit. i have orderd pcie extension cables and a black sata cable . i may get some sort of lighting not sure yet
With the PCI-Ex cables sorted out that will look really nice indeed!
Just need a Lian Li dvd bezel cover modifying now to finish it off :D
