- 13 Jan 2004
- Leicestershire
i'm 'normally' ok with car issues but this has me baffled.
2.3l cylinder Ford Galaxy 1997 (R reg).
what i tried to do?:
give it new plugs and leads. it has coil packs so i counldn't change these but 4 plugs + 2 leads i could. so i did. bad move.
Reason being:
It wouldn't start after the new plugs (gapped per size instructions on packet) and put the 2 new leads on.
Remedy Tried:
put old plugs and leads back on.
Symptom:
It still wouldn't start. It was mega low on fuel so a tenner was put in by aid of jerry can. It will 'try' to catch every now and again but generally it's ******.
i've read about power relays being issues and i would normally check the plugs for a spark but you have to remove a cover every time and replace it to even get it to try and catch so i'm guessing it earths somehow.
What would you do? Apart from burn it.
Crap weekend is now a mega crap one.
Reason being:
Remedy Tried:
Symptom:
