What HDs come with the mac pro
It varies. Apple don't specify a particular vendor and model.
They should do for the ridiculous amounts they charge. To upgrade from the default 640gb to 1gb drive when buying a mac pro costs £80. You could buy a second 1tb for less than that.
You're forgetting that the average apple user really couldn't care less about model - just that it does the job.
What's that got to do with being savagely gouged on price?
He's just saying they don't because nobody really cares, it's a hard drive, spins at a given speed and stores files. If you want the couple of percent extra that model x might give you you're already buying the wrong machine to be honest.
And the price gouging (as you're calling it) is common across the industry and comes at least partly from turning an off the shelf SKU into a custom specification, which costs the manufacturer more than the cost of the other hard drive. HP and Dells server drives commonly cost far more than the cost of the bare drive and carrier could conceivably cost (and in Dells case they actually force you to buy their drives now, which isn't the case here), and they won't tell you which model drive you're getting either, merely interface type and rotational speed.
No. I know that for sure because when I took my Mac Pro in for some warranty work the original drive wasn't in it. In fact I don't think I know where my original drive is!
WD Black 1TB, which actually at the time of launch was the best 1Tb drive about, no?
"He's just saying they don't because nobody really cares, it's a hard drive, spins at a given speed and stores files. If you want the couple of percent extra that model x might give you you're already buying the wrong machine to be honest."
^ This.
I upgraded from the 640 to 1Tb because I couldn't be bothered selling the 640Gb!
I couldn't care less which 1TB came with my 2009 MP TBQFH.
HDDs are treated as commodity items. The Warranty is handled by the system manufacturer.. so what difference does it make ?
Usually you will get an indication of the speed of the drive (5400, 7200 etc).
