- 31 Dec 2008
don't know allot about home theatre kits as i've never owned 1 but would like 1 to be pluged into a sky box and a pc at the same time. its my understanding that when you purchase a a theatre kit you then need to plug it in to something else via optical lead to get it to work on something else other than the included dvd player or whatever, or can i just plug something into the tv (my tv has an optical out port) to get it working on everything that should come out of the tv? i play pc games on my tv allot. thanks
If you really wanted everything to be in 5.1 then you could always look at buying one of the Dolby Digital Live/DTS Connect sound cards, they will encode everything up in DD or DTS on the fly and send it down the optical cable
