Corsair H50 cooler for the GPU?
9 Mar 2007
Cornwall
stupid question
Anyone know if corsair is going to release a H50 cooler or the GPU?
seems like a gap in the market (sealed untis for GPU, not Watercooling kits)
Good idea, they would have to sell the unit and then lots of brackets separately though, and I could see some people buying just the cooler and trying to get it to work :p
Doubt it, much more hassle to fit a GPU cooler to a wide variety of cards.
Plus if used with the H50, needs two 120mm fan spots :/
well i wasn't talking about the h50 itself, more like a new flat single slot block like normal water blocks that are seal to another radiator, that you can mount behind the cpu raditor
therefore 1 120mm fan might do it. fan -> cpu rad -> gpu rad
although the gpu mems need cooling as well!
same goes for the Asetek's Vapochill, why is that CPU only? can't it be a dual cool solution!
seriously who want -10c on a cpu only?
dont they do something similar to what you want made by coolit which is a double raidator thing with interchangable coolers for gpus cant remeber the full anme fo it but it was in the overclocking cooling sections of this foum so a search might come up with some more answers
Thermaltake "tide water" tried liquid GPU cooling did it not? Think it was loud and not too effective as I recall..
to separate solutions are needed. not a CPU to GPU link then to rad
surely its easy to manufacturer a H50 with a gpu block,
unless gpu require a bigger rad
I don't think there will be anything from Corsair soon with regards to GPU coolers, they have just announced the release of two new CPU coolers A50 and A70 HERE. I wouldn't count on them not having one in the works though... that Omni looks interesting Helios!
Following this thread with interest.
Cooling for my graphics card in my shuttle is terrible, something like this would be perfect if OCUK stocked it.
