Worth upgrading from 3850 pro with a £90 budget?
26 May 2006
Edinburgh
I currently have a 3850 pro GFX card, would it be worth me upgrading with that kind of budget? I run games at 1280x1024.
My processor is a E2140 only slightly overclocked to about 2.4ghz as I cannot get it to hold.
4850 , for around 40 : ).
+1
A second hand 4850 can be had for about that much and would give a nice performance boost, then you could spend the change on an e5300 and clock the nuts off it. That is provided your mobo and cpu cooler are up to the task.
+1
+1
this guy has nailed it on the head, sell your E2140 for as much as you can, buy a 2nd hand 4850 and then an e5300 which can easily OC to around the 3.2ghz mark on air
+1
^ This. Better card and CPU.
