Hi Guys
Got a problem with a 1.6 Clio (55) ...
The car was opened the other morning and all of a sudden the horn started to sound continually. I’m pretty sure the car has no alarm and also it was as if I had my hand held on the horn. This continued for around 5 minutes and stopped. Then the car started to be driven and the horn beeped another few times but this time didn’t stay on. At first I thought it was an alarm issue but I’m pretty sure that
A. The car does not have an alarm
B. The alarm would not be a constant beep (as if you held your hand on the horn continually)
Now when I press the horn nothing happens whatsoever .... Does anyone have any idea what the problem could be ? I’m going to get hold of another horn to try but i can’t see that causing the horn to go off this morning like it did ?
Cheers
Sam
Cheers
Sam
. Bought a Haynes (for this any many other problems) but just hope it's nothing expensive!
