Intel i5-750 in a Gigabyte GA-P55M-UD2 Motherboard with GSkill Ripjaw Ram and a OXCZ moDStream 600W PSU. Arctic cooling Freezer 7 Pro rev 2 Cooling.
Ran Prime 95 Small fft earlier today for 90 minutes no problems, highest temp recorded was 76C . . . but as I didn't have the fan on teh Freezer 7 that was to be expected, still the system was stable . .. put the Fan on and got core temps around 26 degrees lower using Prime 95.
Decided to do an over clock
Base clock to 190
System memory Multiplier to 8 (Taking memory to around 1550Mhz)
CPU VCore to 1.35
QPI/VTT to 1.37
PCH Core to 1.14V
CPU PLL to 1.9V
DRAM Voltage to 1.64V
System booted normally, and straight into Windows. Started CPU-z and overclock had been applied now running at 3.8GHz . . . Core Temp showed around 47C . . . Started Torture test of Prime 95 . . . Temperatures crept up to around 80-82C . . . a bit warm .. . . left the system running for 30 minutes . . . came back and all was shut down.
System now refuses to power on, get a slight spin of the fans as I switch on but that is it . . . Guess I've killed it? . . . suppose I should clear my CMOS and see what happens then?
Any other ideas?
Base clock to 190
CPU VCore to 1.35
QPI/VTT to 1.37
PCH Core to 1.14V
CPU PLL to 1.9V
Any other ideas?
Still CMOS battery removed . . . Time for a quick drink and try again I guess. The funny side of this is that this is a new rig, that my wife paid a good chunk towards . . .because at Christmas she turned my old one on . . . and took the PSU and Graphics card out . . . not looking forward to telling her today when she wakes up
