WEDNESDAY AGAIN...... MEANS IT'S THIS WEEK ONLY......
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
We have 15 brand spanking new deals available on This Week Only just for you. Some of the highlights are as follows:-
Club 3D ATI Radeon HD 5770 1024MB Overclocked GDDR5 PCI-Express Graphics Card @ £135.98 inc VAT
Get the most out of the successful HD5700 series with the Club 3D HD5770 Overclocked Edition graphics card. For maximum performance in your gaming rig and real innovation with DirectX® 11 gaming. Loaded with advanced technology, this graphics card has the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity technology*. Using ATI Stream technology**, accelerate even the most demanding applications and do more then ever with our PC. Enable realistic visual effects and an explosive HD gaming performance to dominate the competition.
- Core Clock: 875MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4900MHz (Effective)
- Processing Cores: 800
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
Only £135.98 inc VAT.
ORDER NOW
OCZ StealthXStream 600w Ready Power Supply @ £54.99 inc VAT
Designed for the value-minded gamer seeking simple, quiet performance, the StealthXStream includes OCZ’s acclaimed reliability and feature-sets with a lower price point. Ideal for system builders and enthusiasts who prefer a low-key PSU, the StealthXStream focuses on performance, quality, and quiet operation. Even at peak loads, the 600W StealthXStream remains virtually silent and excludes flashy LEDs ensuring the power supply is not seen or heard. The StealthXStream is kept supremely cool with a large 120mm fan features a standard ATX power supply form factor resulting in a compact footprint to accommodate virtually all computer towers. With a sustained output of 600W and four +12V rails to provide uniform distribution of power, the StealthXStream is well-suited for and driving today's higher end systems. The rock solid StealthXStream is built to provide sufficient output to power dual GPU and CPU platforms, complete with two PCI-Express cables and a 4/8 CPU auxiliary connector which are wrapped in a flexible mesh promoting a tidy environment inside the case. The OCZ StealthXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, yet stable supply of power. All OCZ StealthXStream power supplies come backed with an industry-leading three year OCZ PowerSwap Warranty for the ultimate peace of mind.
- 600W Configuration
- OCZ PowerWhisper™ Technology
- Internal 120mm fan
- 3 year warranty backed by OCZ’s exclusive PowerSwap™ replacement program. No more endless return-for-repair loops!
- 150 x 140 x 86mm
- ATX12V v2.2 and EPS12V
- OCZ ConnectAll™ universal connectors:
- 1 x 20+4Pin ATX
- 1 x 4-pin/8-pin CPU (supports double CPUs/supplies stable voltage)
- 2 x PCI-E (1 6-pin & 1 8-pin)
- 6 x 4-pin peripheral
- 1 x 4-pin floppy
- 3 x S-ATA
- High efficiency 80% @ 115V (Typical load) 83% @ 230V (Typical load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- MTBF:100,000 hours
- 100~240Vac 10-5A 50/60Hz
- +3.3V(36A), +5V(30A), +12V1(18A), +12V2(18A), +12V3(18A), +12V4(18A)
Only £54.99 inc VAT.
ORDER NOW
Microsoft Windows 7 Home Premium - Retail (Full Version) @ £89.99 inc VAT
PLEASE NOTE: This is the full retail version and does not require a prior installation of Windows as per the upgrade version. Both 32-bit and 64-bit discs are included.
Windows 7 Home Premium offers a rich, dynamic entertainment experience on your PC, making it easy to create a home network and share all of your favorite photos, videos, and music. You can even watch, pause, and rewind TV or record it to watch whenever and wherever you want.
- Record TV on your PC: Watch, pause, rewind, and record TV, movies, and other video content with Windows Media Center, updated to manage a single TV guide containing both standard and digital high definition TV shows.
- Personalise your desktop: Easily change backgrounds, window colours and sounds to reflect your personal style. You can even turn your desktop into a slide show of your favorite photos.
- Share files across the various PCs in your home: Use HomeGroup to connect your PCs running Windows 7 to a single printer. Specify exactly what you want to share from each PC with all the PCs in the HomeGroup.
- Pin any program to the taskbar: Any program is always just a click away - and you can rearrange the icons on the taskbar just by clicking and dragging.
- Stream music files on any network-connected device: Just open Windows Media Player, right-click on what you'd like to hear, select Play To, and you'll see a list of devices and PCs on which you can play your music.
- Find virtually anything on your PC - from documents to photos to e-mail: Just click on the Start button, and enter a word or few letters in the name or file you want into the search box, and you’ll get an organised list of results.
- Access recently used files with just two clicks: Right-click the relevant program icon (such as Word) on your taskbar and Jump List will show your most recent, frequently used, and pinned Word documents.
Only £89.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K2000 2TB SATA-II 32MB Cache - OEM (0F10311) @ £112.99 inc VAT
The Deskstar 7K2000 hard drive delivers a colossal two terabytes of storage capacity and 7200RPM performance in a standard 3.5" form factor. Now in its fourth-generation, the 7K2000 is based on a robust mechanical design that continues to set the industry standard for quality and reliability. The Deskstar 7K2000 offers an exceptional blend of capacity and power efficiency, with idle power savings over previous generation products up to 10%. On a watts per gigabyte basis, idle power has improved over 120%. Leveraging eighth-generation power management technology, including power-saving innovations like HiVERT technology, this drive delivers best-in-class power management and thermal emissions to help manufacturers meet energy compliance targets and extend drive life.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Warranty: 3 Years
Only £112.99 inc VAT.
ORDER NOW
Just ordered the Hitachi HDD and windows 7. Hope the HDD is OK, not had good experiences with Hitachi before.
I have the hitachi in my PC at home. It's a great fast reliable drive. Read and write times beat my Seagate 7200.11 500GB drives.
Damn, and my pay day ain't for another 2weeks :/
In the need of a bigger HDD
500gig just ain't that much these days:p
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Is this any better than the XFX 5770 XXX 1024MB?
