yeah - that's same issue as I am having with my ASUS board. The machine attempts 3 boots before post and then works.
Another problem I was having last night was my printer kept cancelling its jobs - it seems that there want enough power being put to the USB port through the front panel connector headers. Once I disconnected my ext portable drive and plugged the printer into the back of the PC it worked again.
It suggests to me a power issue but down to the MB and not the PSU. What a load of messing about over such a cheap card.
4650 would be fine as I'm running one of those off a 300W PSU at the moment (the 5670 was supposed to replace it). Or you can just try the 5670 and return it under the distance selling act within 7 days if it doesn't work.
Posted this in the other thread on a similar subject, but thought I'd put it here too:
Just to update everyone on this, I installed a new 785G motherboard this weekend (plus new cpu and ram) but using the same PSU I had before. And the 5670 card worked first time.
So for anyone else searching this thread in the future, I can as good as confirm this is a motherboard incompatibility issue that is stopping these cards from POST ing, not the PSU, not the card itself.
