NASA Scientist Thinks Chile Earthquake Shifted Earth's Axis
Curious, how does rotational momentum get affected by an earthquake? As far as I'm aware, nothing was ejected into space, and that's the extent to which my Physics knowledge goes.
edit:
http://en.wikipedia.org/wiki/Angular_momentum
Okay, lets say the earthquake brought more material to the earths surface. To conserve momentum, that material would have to be travelling slower (radians per second). But obviously it can't travel slower than the rest of the surface and so slows the motion of the crust?
Sound about right?
I presume what happened was the earthquake moved mass up overall (eg seawater replacing the denser rock lower down or something) so that it's like spinning round on a chair and then putting your legs out.... But really I have no idea :o
Surely for the day to be shortened then the planet needs to have sped up rather than slowed down?
I can understand the length of day changing veeeery slightly, by changing the earths moment of inertia (think about a roundabout or similar, if you move your weight towards the centre, it spins faster). 6.8 milliseconds sounds like a massive change when something weighs as much as the earth though! To the maths!!!
Using conservation of momentum, I came up with this lovely equation:
dI = 2/5*mr^2*(1-(T-dt)/T) where dI = change of moment of inertia, m = mass of earth, r = radius of earth, T = length of day, and dt = change in length of day
Plugging in numbers that means for a 6.8microsecond change, earths momentum must change by 7.65x10^27 kg.m2. In order to get that change, you'd need to launch 6000 cubic km of water 100km into the air! Earthquakes are powerful but not THAT powerful :confused:
Edit: Doh! On my second attempt I get 5.47x10^21kg.m2 and only 0.004km3 (4 million tons). Must have forgotten to carry the one.
How about you have a gander at the brain of someone who faints when they see brains?
Could do the trick!
If not at least you'll be well rested. :)
