My Vectra VXR needed a new gearbox under warranty. It shared its F40 gearbox with most other models in the range (including the 1.9 Diesel) so wasnt special or anything.
It got fixed under warranty (@ 2 years old), but the price on the invoice was an F40 gearbox at £1100. Obviously it was warranty work so no labour included. So the price for parts only they have quoted you is correct.
I can easily believe to refit a brand new gearbox can be £2000 at dealer labour rates of £100 an hour. 6 Hours labour at £100, plus gearbox at £1110 is £1710 + vat on both which is £2009 inc vat. So they are charging a little under £100 an hour, or maybe slightly more and less labour time. You get the idea.
Are you being ripped off ? No, any VXL dealer will charge the same labour rates and part rates (my VXL dealer was charging the same so theres your proof)
Can you get it cheaper ? HELL YES ! Local garages will charge half the labour rate, and be able to source the parts cheaper.
Give autovaux a ring and see how much they can find you a gearbox for.
www.autovaux.co.uk. Get quotes from garages on the ammount of labour they reckon it will need and their labour rates to build you up a picture of total cost. It could easily be half the £2000 the dealer wants doing it this way.
Will you get it under warranty ? not a cat in hells chance. Once the 3 years is up they dont want to know. Your mate can try, but i'll tell you now he'll likley not got anywhere.
