Patriot G series
26 Feb 2010
The first set you linked to was tested on socket 775 setups, ie X48, X38 & p45 chipsets as this memory may require a higher voltage to operate, the 2nd set labelled Sector 5 will work on P55 range ie the i series cpu's from Intel.
I bought the RAM in the first link for my latest build which has an i5 and a Gigabyte P55 Motherboard and works fine.
