- 19 May 2005
After careful experimentation with the latest BIOS from Asus, Overclockers UK are proud to relaunch the Rampage Extreme i7 930 4.2GHz bundle.
The latest BIOS has allowed us to achieve 4.2GHz on a consistent and reliable basis, offering our customers unparalleled 'out of box' performance.
*OVERCLOCKED* Intel Core i7 930 2.80GHz @ 4.20GHz Max / Asus Rampage II Extreme Intel X58 Motherboard / Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz DDR3 Bundle @ £719.99 inc VAT
Representing the cream of the crop of today's bleeding edge performance hardware, OcUK's 'Extreme Bundles' are selected to satisfy the needs of the most demanding enthusiast. Available with three different levels of overclock your ideal bundle is just one option away.
This is our fastest bundle to date! We take full advantage of the Asus Rampage II Extreme capabilities by pushing the chip to its limits, ensuring you have the fastest hardware on the planet.
OcUK Overclocked Bundles feature carefully selected components tested to assure compatability & stability, guaranteeing the integrity of the overclock.
We worry about the fiddling and tweaking, you just enjoy the performance.
This bundle ships pre-built and pre-overclocked direct from our Technical Department. All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
This Bundle contains the following components:
1 X Intel Core i7 930 2.80GHz overclocked up to 4.20GHz!
1 X Asus Rampage II Extreme Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
1 X Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz DDR3 Memory
1 X Prolimatech Megahalems Performance CPU Cooler (Socket 775/1366)
1 X Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM
1 X Arctic Cooling MX-2 Thermal Compound
Note - This bundle will take upto 4 working days to complete and be tested. This is due to the fact not all processors will run sustainably at 4.20 Ghz and chip yields will vary week to week.
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours.
Note - The Rampage II Extreme motherboard is one of the largest available and will overhang the last risers on your motherboard tray, please ensure you have enough room in your case before ordering.
Note - The bundle operates above manufacturer specifications, as such it requires a quality power supply to operate with guaranteed stability. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range.
Note - Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £719.99 inc VAT.
ORDER NOW
- Maximum Speed
- Maximum Stability
ORDER NOW
