- 10 Sep 2008
My car has for the first time got a bit warm today, normally the coolant temperature doesn't move unless its a hot day and I've been sat in traffic for half an hour. Today I was doing 50mph through some road works on the M1 and the temperature began to rise, eventually the engine fan came on and stopped it getting too hot, once I left the road works and got back up to 70mph the temperature dropped away and all was normal again.
When I drove later the car is still getting hot quickly, a quick stop at traffic lights gets the needle on the move.
Fluid level is normal and nothing stuck around the radiator, any ideas?
Its a corsa by the way - I know thats the biggest problem.
, but if it was my car I'd simply test it without the thermostat.\
. Despite warming up exceedingly quickly the car never actually strictly speaking overheated. Once the electric fans (which shift an utterly retarded amount of air) kicked it the car was able to maintain a perfectly reasonable temperature of 90C - 95C. It just goes to show that there could be a massive problem with your cooling system and you may not even notice! Not that I recommend running your car without coolant
