hi guys, this is my 1st post, so pls accept my apologies, if i make any mistakes.
I have just bought the following components to build my pc:-
AMD II Phenom x4 955 Retail
Kingston 2gb Ddr3 1333mhz Hyperx Memory Cl7(7-7-7-20)
MSI 770-C45 AMD 770
HIS HD 5770 1GB DDR5
Samsung SH-S223 22X
Powwa 600W 12cm Fan >80% High Efficiency PSU
Black/Silver Mid Tower Case with Front Panel Temperature LCD
I built the whole system, but when i power up, the cpu fan works, but there is no bleeping sound or any display at all. FYI the case has no internal fans, but i just want to test that the rest of components are okay.
I have also taken out everything, including gfx card, but i left the cpu, mobo and when i took out the memory, this is the only time when i hear the MEMORY NOT INSTALLED beeps.
FYI, the motherboard has no troubleshooting guide, although it has these 4 leds, that tell the installer that the CPU has gone from phase 1 to 4 and these are all lit.
What could be the problem?
thanks for your help
MSI 770-C45 AMD 770
Samsung SH-S223 22X
