What ATI card would be the same as my 260GTX
Where abouts is the members market i have never used it before?
I have been looking at the 5850 and it looks like the one for me! 1 question tho i see it uses ddr ram i want to make sure that my motherboard will support this ok. I cant post a link of the mo board cos overclockers dont seem to have it anymore but i will put the model number below if someone could maybe google it and check the spec for me id be very grateful
ASUS M4A785D-M PRO785G (SOCKET AM3) DDR2 MICRO ATX
thanks again
I'v never heard of that issue before... But maybe others can answer you better.
Do a search in the FAQ for members market. It looks like it just needs to be setup...
Rroff you don't happen to know if I get something like a cheap 260, can I use to for PhysX and cuda with hacked drivers in W7?
You can... but (sadly) not much point really unless your planning on developing for either... and you'd be better off really with a 9800GT or GTS250 if your gonna do that.
I'm going to be pretty busy for a while so won't really have time for gaming much etc. so have been thinking about a downgrade. you don't fancy offloading one of your 260's and a cash sum for my 5870? ;)
I know it's Ati...
Do you see a blue trust button on your post? If so try clicking that.
I did that mate an enabled it but still cant find the members forum?
can someone tell me if i need to get a new board as mine only supports pci x16 2.0 and the 5850 needs pci x16 2.1
thanks mate got nothing on my trust yet where abouts will i find the market once im allowed to use it? if you still interested the the card we could maybe sort something out
cheers for that mate its not there yet but it does state it can take 24hrs to activate.
I got one last thing mate, im looking to do my first overclock on my new card, when i start to up the core and the memory speed do i need to change voltages or will it do it automatically?
thanks again
