- 16 Jan 2003
- Nottingham
Love the scale of the Unigine results
Much better min FPS on Crysis Warhead though.
That graph shows exactly why you shouldn't believe any test untill the card is released.
The green bar is double the size of the red bar but only around 50 points more, it's laughable.![]()
Having done a little research - that minimum value does appear to be correct(ish) due to the lack of VRAM I would guess. The average values don't seem to match any other figures I can find for either card tho.
I don't understand this really. Have Nvidia spent all this time making a card that is only a bit faster than a GTX 285??![]()
looks like gtx480/5870 are gonna be trading wins...
personally im waiting for fermi's smaller derivatives to appear so 5770 prices might drop a bit...
Again, people don't seem to understand minimum frame rates.
If the average is say 80FPS, max 120FPS, the minimum could be anything from 79 to less than one FPS without the card being a poor performer.
It only takes the FPS to drop once to that number for a fraction of a second and there's your minimum FPS.
You could be playing for hours at 80FPS, then go in to a new area and the FPS dips to 2FPS for a whole second, while new data is being loaded in to RAM.
That will probably not happen.
I'd suspect you'd get some GT200 based cards to fill in the lower performance areas to be honest.
According to Charlie:
'The GF100 GTX480 was not meant to be a GPU, it was a GPGPU chip pulled into service for graphics when the other plans at Nvidia failed.'
This is now looking to be about right i think (if the current results prove accurate when we have plenty of analysis post 26th). Fermi is certainly going to be a total monster for CUDA/OpenCL, but it seems that a good chunk of the 3b+ transistors are not as useful for gaming as we might ideally like.
I'm still interested to see how things look when they are launched, still a lot of unanswered questions, possible performance increases with future drivers etc.. But for now it looks like it will just be a good gaming card, not an incredible one.
