Caporegime
- 9 Nov 2009
- Planet Earth
I would get the 95W version of the Phenom II X4 945 for around £122. You could also get a Antec 300 case for around £43.
Just wondering if anyone could have a look over my selection before committing to buy!
The whole unlocking is a bit hit and miss and the stability of your system is not guaranteed, the X3's are X4's that didn't quite make the QA cut, so there is often a reason for the core(s) being locked. The general concensus seems to be that if you want 4 cores, buy 4. If you're happy with 3, buy 3 and (maybe) unlock.
Are you a student?
There are essentially two choices: You can either buy discounted OS for around £40, or what I'm doing, use MSDNAA to get it for free, the only catch is that you can only get updates for the MSDNAA license for the length of your study, after that you can continue to use it but won't get updates, which works out pretty good, means I can use windows 7 for another 4 years without paying for it lol.
The £40 offer though gives you your very own license.
I'd ask your computing department if your Uni/College has membership and if so to set you up with an account
didn't the windows 7 student offer finish a couple of months ago?
