is my 3Dmark 06 ok?
Man of Honour
9 Jan 2010
hi, just built me new rig (see sig) as a first time n00by :)
i ran 3dmark 06 with everything @ stock and was only getting around 19,800 so i was told their might be a problem somwhere.. maybe the 2 gfx wernt working in Xfire ect :/
ive just OC'd my i7 920 to 4ghz and ran it again and got 28,704 and with it OC'd @ 3.2ghz i get around 23,500 so does this sound about right for my rig? can i take it from these scores that the gfx are fine and the CPU just needed tweeking up? or should i still expect to be getting a higher score?
thanks for help
i got 18944 with my signature pc run at defaukt 3d mark settings.
will take a look at that vantage and see what i get.
cpu score for my 3d mark score was 5855
Ive just run vantage for you.
3dmark score 18012
Gpu score 17800
Cpu score 18679
This is with all stock setting.
I have turbo enabled and speed step turned off which give a cpu speed of 2968.7mhz on cpu-z
3dmark06 score 19636
Cpu score 5245
3dmark score 18012
Gpu score 17800
Cpu score 18679
Cpu score 5245
That cant be right. I ran it was an overclocked Q6600/8800GT and gets the following
P8027
GPU - 6407
CPU - 33191
P8027
GPU - 6407
CPU - 33191
I have a i7 930 and a 5870 it is correct.
My i7 replaced my qx6800 and at stock clocks the i7 is as fast as the qx6800 when its 3.8 gig.
My scores are with the pc all stock clocks all i altered in the bios was to set the correct ram speed and timings and turn off speed step.
I have a old score with my qx6800 and 4870x2 and with the cpu at 3.6 i scored 3dmark vantage 13983 i didnt write down the cpu or gpu scores sorry.
