Vapor-X HD 5850 soon to be available?
19 Dec 2003
Grimsby, UK
Fairly old news but looks like Sapphire will be launching a Vapor-X HD 5850, should be cheaper than the Toxic - been having a look around £230 - £250 seems the pricing - none in stock anywhere though.
NOW SAPPHIRE LAUNCHES TOXIC and Vapor-X HD 5850 - Feb 18, 2010
Successful graphics processors get award-winning coolers
Combining the highly successful HD 5000 series graphics architecture with its award winning Vapor-X cooling technology, SAPPHIRE Technology is now shipping two new graphics cards – the SAPPHIRE HD 5850 TOXIC Edition and the SAPPHIRE HD 5850 Vapor-X model.
The SAPPHIRE HD 5850 TOXIC Edition and the SAPPHIRE HD 5850 Vapor-X models are both SAPPHIRE original designs based on the latest 40nm graphics architecture from the ATI division of AMD. Both models feature 1440 stream processors and 72 texture units delivering the fastest performance in class as well as supporting ATI Stream technology. They support the advanced graphical features of DirectX 11, and deliver spectacular video clarity, speed and visual effects, including over multiple monitors whilst working at lower operating temperatures and significantly more quietly because of the SAPPHIRE award winning Vapor-X cooling technology.
Designed for the enthusiast user, the SAPPHIRE HD 5850 TOXIC Edition is factory overclocked to 765MHz core and 1125MHz (4500MHz effective) memory speeds. The SAPPHIRE HD 5850 Vapor-X model is also faster than the standard HD 5850, with shipping clocks of 735MHz core and 1050MHz (4200MHZ effective) for the memory. SAPPHIRE’s World leading Vapor-X technology not only allows the cards to run as much as 15 degrees C cooler* and 10dB quieter* than the standard models, it provides additional headroom for further performance tuning (overclocking).
The SAPPHIRE HD 5850 TOXIC and Vapor-X models speed existing DirectX10.1, DirectX 10 and DirectX 9.0 games and applications, and support stunning new levels of detail, transparency and lighting effects in the latest releases of software using DirectX 11. All of this comes with the modest active power consumption of less than 160W – and using Dynamic Power Management the card has a new super low-power idle mode at less than 30W.
Both cards support the latest features demanded by Microsoft DirectX 11, including DirectCompute 11 instructions, hardware Tessellation and multi-threaded communications with the system CPU. These combine to provide new capabilities for the interaction between transparent objects, new lighting and accelerated post processing effects as well as physics calculations and accelerated video transcoding.
The SAPPHIRE HD 5850 models have the latest on board hardware UVD (Unified Video decoder) considerably reducing CPU load and delivering smooth decoding of Blu-ray™ and HD DVD content for both VC-1 and H.264 codecs, as well as Mpeg files. In this series the UVD has been enhanced to be able simultaneously to decode two 1080p HD video streams and to be able to display HD video in high quality with Windows Aero mode enabled. HDMI capability has also been upgraded to HDMI 1.3a with Dolby TrueHD and DTS-HD Master Audio support.
In addition to spectacular image clarity, speed and visual effects, the SAPPHIRE HD 5000 series supports a new multi-monitor mode known as ATI Eyefinity. This allows a single GPU to display a choice of images over an array of several monitors. With its versatile output configuration of two Dual-link DVI connectors plus HDMI and DisplayPort, the HD 5850 series supports up to three monitors** in ATI Eyefinity mode, with a resolution of up to 7680 x 1600. This opens up exciting possibilities not just for multi-screen gaming, but also for information systems, multimedia systems and promotional displays.
The SAPPHIRE HD 5800 series is supported by AMD's DirectX 11 WHQL certified graphics driver which delivers support for all of the key DirectX 11 level features required for new gaming experiences and acceleration of next generation high performance applications as well as ATI Eyefinity and ATI Stream technology.
Source
Is that going to be Gigabytes equivalent to voltage tweak + afterburner, and will it unlock upper OC limits on Gigabytes cards?
Otherwise, they are still inferior to Asus and MSI.
Have you seen the super overclock 260 and 275?
Thats how you do it. Massivly cherry picked cores that run faster and produce less heat, large overclocking headroom.
IMO the super overclock series is the only interesting one of the tweaked cards.
Oh, just hand picked cards.
But Im sure that everysingle 5800 can overclock to 1 Ghz using voltage tweaks, they just the unlocked frequency limits, which Asus and MSI have. I were expecting gigabyte to have something like that by now.
Yeah but we are talking cores that are OCed 25% are only 2C hotter than stock but the fan (same on both cards) is generating HALF the noise (3dB) to keep it there.
I have just looked for the 5850 vapour X and it looks to have the same cooler as the Toxic.
Is the Toxic cooler non reference, ie same to Vapour X ??
Vapor-X is basically Toxic without the factory overclock. The lack of software voltage tweaking really limits the overclock on these cards, which is a shame as they have a really nice performing quiet cooler. However for overclocking your are better off with standard reference cards.
You can always flash them with Asus/MSI BIOS though.
Actually if you flash the asus bios on the cards you will brick them untill you blind flash/flash them with another card.
I tried on the toxic 5850.
