usb flash drive transfer speeds
Caporegime
17 Feb 2006
Cornwall
Fastest USB pen drives I've found are 30mb/s read and 25mb/s write. Those are something like £60, so not for me.
Down to the next tier of pricing, the best I could find for around £10-15 was 20mb/s read and 8mb/s write (Transcend V30 8gb). 8gb is the lowest capacity I can buy for my needs.
A well-known auction site seller is listing an 8gb drive with read 20mb/s and write 14mb/s... but... no brand, no model number, and from Honk Kong. It sounds like a gamble to me!
What I've found tho is that the majority of commodity drives are still slow as pond water. Reads of 10mb/s and writes of 3mb/s are common on most drives. Sad, really.
So anyone found a good, zippy drive that didn't cost the Earth lately?
My 16gb Sandisk i bought from Amazon a month or so ago for £18 has speeds of 30mb/s. Are you plugging it directly into a USB socket from the motherboard? or are you using some kind of extension cable?
I haven't bought one yet.... :D
What are you getting for write speed?
The Verbatim 8GB TUFF-'N'-TINY is worth a look.
They're fairly cheap and when I tested I got a 30.85 MB/Sec read and a 13.77 MB/Sec write. You can see my test result on the page linked above, it's almost at the bottom against my user name.
Thanks bremen, tho google isn't finding any UK suppliers for that one atm.
[edit: nm, found it now...]
Getting flash media from there is a bad idea, many people have ended up with devices reporting more capacity than they actually have. e.g. '8gb' card that cant write past 2gb.
I need to resurrect this thread :p
The flash disk I bought back in march was fine and fast and all that jazz, but it doesn't have a friendly name. By that, I mean that it doesn't have a "name string" stored on it.
And because of that, Gigabyte boards crash when trying to boot it. Other devices have a name string like "USB Disk Pro" and these boot just fine. The Medion 8GB disk has no name string, and the Gigabyte boards do some crazy divide-by-zero-then-dereference-a-null-pointer stuff because of that :p
So I once again need a fast USB disk, but with a name string! And I figured I should just ask the audience again ;)
