BFBC2 benchmarks
Caporegime
14 Dec 2005
armoy, n. ireland
I was running it on an 8800gt up until yesterday, rest of my rig is an i7, 6gb ram, (currently at stock) A quick bench using fraps listed, min 19fps, avg 39fps, no aa/af, res at 1680x1050 (dropped from my native 1920x1200) running under directx 9 on win7 64. Ive replaced the 8800gt with a gtx 275
5 Feb 2009
N. Ireland
as per sig, all at stock. 1920x1080 res.
In game settings:
Level of detail; High
Texture Quality; medium
Shadow Quality; medium
Effects Quality; High
AA 2xMSAA
AF 4x
Vsync; on
HBAO; off
depending on whats happening on screen fps between 30-60. very occasionally dips to low 20's.
13 Feb 2009
London
Same system here. I've been testing another 275 sli. running 1920x1200 everything max DX 10. runs sooooooooooo smooth.. worth the upgrade :)
One 275 just dont cut it really.. :eek:
Caporegime
14 Dec 2005
armoy, n. ireland
On my current 275 (640 core clock xfx version) i run it on high at 1920x1200, 2x aa, 4x af, hbao off, runs pretty well, i could go sli gtx 275 as a friend has offered me another identical card, but i think ill give it a miss, probably get myself a couple of 5870's and give crossfire a try, bit peeved off with nvidia cards lately, had a gtx 280 die then the first replacement 275 died as well, but ill whack my i7 back to 4ghz tomorrow, maybe try a quick oc on the 275 and see how bfbc2 fares. But so far the 275 is a bit of a let down compared to my old 280.
Caporegime
14 Dec 2005
armoy, n. ireland
Not from my experience, my current 275 has the same core speed as the 280 i had, but there was 1gb of ram on the 280, 896mb on the 275 gtx, cant compare on bfbc2 as i never got to try it with the 280, but in all my other games the 275 doesnt run as well as the 280 did, theres not much in it, but i definitely notice a drop in performance. Ill load up my oc profile for the cpu at 4ghz, then see how it compares, bu currently with my i7 at stock it seems quite a bit slower than my rig was at stock with the old 280, but it does run a wee bit cooler.
13 Feb 2009
London
I was thinking of 2 Asus 5850. but i read a lot of people we're having very slow loading issues in BFC2. not sure if anyone else does.
I tried a 5870 with rfactor. for some reason it stutters like mad, put my 275 back in, and was fine. think the nvidia card suit rfactor more:rolleyes:.
