What ATI card For 1080p Gaming??
15 Oct 2007
Bedfordshire, UK.
Im going to be building a cheap gaming PC to go under my 42"LCD TV, so will be gaming at 1080p resolutions. What ATI card would i need for playing current games, i dont want to but anything that will be over kill at this resolution, so what ATI series should i go up to 5670 or sould even this 5 series be regarded as over kill for 1080p?. Im after something that will play stuff like Dirt 2, Bad Company 2, and the new STALKER game etc at max settings @ 1080p
For 1080p, Ideally you would need a 5850. You could get away with cutting corners and get a 5770 instead, but running 4AA at 1080p and in dx 11 mode could struggle a bit at some games.
Yeah, a 5770 would be OK but not ideal. My mate has one and it's fine in everything but with a lot of AA and Crysis obviously.
Ok thanks for the input, im not a massive user of AA and AF usual, have AA @ x2. As 1080p isnt a massive resolution would the memory stzie (512 or 1GB) effect performance a great deal
For 1080p, get the 1GB card. The only people that should even consider 512MB card are those that game at 1680x1050 or below.
OK, this is what im thinking of getting then:
i3 530
Gigabyte H55M-S2H
Geil Value 4GB (2x2GB) DDR3 1600MHz
Western Digital Caviar Blue 640GB
Sapphire ATI Radeon HD 5770 1024MB
OcUK 650W Dual Rail High Efficiency Modular PSU
Silverstone SG02B-F Evolution MicroATX SFF Case
Come to approx £510, not sourcing all parts from OC. Was hoping to get it around the £400 mark but seems impossible, even c2d cpus seem to be more than i3's now :eek:, and same for 1156 and 775 mobos with the older types being more :eek: :eek:.
Now can media centre display games, like it does movies and music. As i would like to be able to just power on the PC and use a control pad to get into games, withou the use of a keyboard and mouse. I would like the pc to be as much like a console as possible??
i3 530
Gigabyte H55M-S2H
OK two things:
i) CPU: You should spend around £50 extra by getting a i5 750 instead of the i3 530. 750 is a quad-core and 530 is just a dual-core...more and more games are taking advantage of using the extra cores and they increase frame rate hugely in games like Battlefield. Just refer to the following test:
http://www.overclock.net/pc-games/659536-contagion-review-dual-core-vs-quad.html
You get a i3 530 now, and I can almost guarantee you will regret not spending just a little more getting a 750 instead in the future.
ii) Motherboard: Although the Gigabyte H55M-S2H is listed as supporting Crossfire, but in fact it doesn't. The 2nd PCI-E X16 slot would only has 4 lanes, making it incapable of actually running two graphic cards in Crossfire. In order to run Crossfire in 8x/8x, you would need something like a Gigabyte GA-P55M-UD4 (which cost nearly £140). So I really think you should carefully consider if you are certain that you are going to get a 5770 instead of a 5850, since adding another 5770 to Crossfire in the future would not be an option for the Gigabyte H55M-S2H.
Can't cheap-out at 1080p and max settings, 5850 it is.
That's simply not true.
People seem to keep forgetting just how the last generation of cards performed.
A 3870 and 8800GT can play a lot of games at 1080p with max settings and some AA.
A 5850 ISN'T a must at all.
It's preferable but not a must.
I have an 8800GT in my HTPC with a Q6600 at 3.8 GHZ hooked up to a pany 1080p plasma, yeah it hurts big time with no AA and burns with AA, were not playing CSS still, even RE5 averages 40-60 with no AA, hardly the most demanding game. So yeah if you want BC2 maxed out, 5850 it is.
OK two things:
Thanks for the info, i know that ill never be going cross-fire so the S2H will be ok for me, i take on board about the cpu though
I bought the best (5870) at the time, if you can afford it why settle for rubbishy choppy framerates, the min you should look at is a 5850 in my opinion.
Edit or even a 4870x2, 4890 etc.
