IN STOCK NOW ASUS 5850 & 5870 1024MB GRAPHICS CARDS FROM £219.98 inc VAT
So tempted to buy 2 ;) Has anyone gone from a 275 to 1 of these whiles playing BFC2 ?
Doe's it perform a lot better then the 275 ?
I dont get great smoothnes via 1 275.
I tried 2 in sli, and it was 100 times smoother @1920x1200 maxed.
I get jaggy lines via DX 10. just wonderd if it's better with the 5850 Via DX 11 ?
Cheers.
Thank overclockers!
Oh yeah :)
thats the entire reason im buying this puppy :D
:D Some might slate the game, but i think it's great fun.
Let me know how it goes. and check couple of things if you don't mind.
When i play via DX 10 with my 275, the game dont give me AA 100%.
Still get jaggy lines on the fences etc. not sure if the DX 11 sorts this out ?
And i read it takes a while to load up via multiplayer also.
Let us know how you get on, and what res you use :D
Whats your name on there :)
Cheers fella..
Finally got round to installing it, had errands to run this morning/lunchtime. Currently using the 10.2 drivers, no overclocks running stock and I must say I'm impressed! The fan stays nice and quiet, but if you manually over ride it and put it to say 50% it gets pretty noisy, at 100% it's rediculously loud.
Running BFBC2 at 1680x1050 including HBAO and never dropped below 35 fps, with HBAO off it was happily running at 45fps. The cpu is an i7 920 @ 3.6ghz for reference.
Saw this and went and ordered the Asus 5850, hope it works well in my older rig.
Reason I went for it is the great reports and my WOW is occasionally completely freezing the PC (even LCD clock on G15 stops) and I have to reset, even though the current 8800gts shows around 52c I think it is the culprit.
Hoping so and extra boost in performance on my 1650x1050 setup.
fingers crossed :)
So running nice and smooth then ?
Did you notice any jaggies ?
Any problems with long loading. and have you tried 1920 x 1200 ?
Well that's if you have the screen for that res :)
Cheers.
