15 Mar 2010 at 15:28 #21 Speed Speed Soldato Joined 23 Nov 2002 Posts 9,878 Location Near Bristol So to clarify, now that you have unticked open iTunes when iPod is attached, has it fixed the whole openning iTunes when Windows starts issue? Your iPod should still appear once plugged in with iTunes open.
15 Mar 2010 at 21:04 #22 tankskun tankskun Associate OP Joined 21 Dec 2005 Posts 1,465 Speed said: So to clarify, now that you have unticked open iTunes when iPod is attached, has it fixed the whole openning iTunes when Windows starts issue? Your iPod should still appear once plugged in with iTunes open. Click to expand... Yes unticking the open iTunes when iPod is attached fixes the opening iTunes when windows starts. But now my ipod is no longer recognised Really appreciate any advice on how to get the iPod recognised again without going through reinstall. Thanks thanks
15 Mar 2010 at 21:05 #23 Speed Speed Soldato Joined 23 Nov 2002 Posts 9,878 Location Near Bristol So if you plug the iPod in to the dock with iTunes already started, it doesn't show up?
15 Mar 2010 at 22:06 #24 tankskun tankskun Associate OP Joined 21 Dec 2005 Posts 1,465 doesnt show up with iTunes started. Have tried with & without dock but no luck still.
15 Mar 2010 at 22:29 #25 Speed Speed Soldato Joined 23 Nov 2002 Posts 9,878 Location Near Bristol Very odd. Does it show up as a USB device when plugged in? I guess you could reset the iPod, bit of a pain if it has lots of music on it, but should solve the issue.
16 Mar 2010 at 19:49 #26 tankskun tankskun Associate OP Joined 21 Dec 2005 Posts 1,465 Speed said: Very odd. Does it show up as a USB device when plugged in? I guess you could reset the iPod, bit of a pain if it has lots of music on it, but should solve the issue. Click to expand... Thank you speed! resetting the ipod has fixed the problem now didn't even lose any songs. and thanks also Ratbag Sharepod is much simpler than iTunes. Thanks all enjoying my music now
16 Mar 2010 at 20:04 #27 Speed Speed Soldato Joined 23 Nov 2002 Posts 9,878 Location Near Bristol No worries, glad you got it sorted!
