The Idea:
Thought I'd share my OC experience with this card since there is very little info through google, other than review sites stating What They have acheived with their review cards...
The Tools:
I used Furmark and MSI Afterburner for testing and overclocks/monitoring temps etc...
I also have a GPU Monitor gadget on my desktop which show Load, Temp and Fan speed.
The Method:
Firstly I ran MSI Afterburner and saved the Default Toxic clock as Profile 1.
Next I ran Furmark Stability Mode, runnning for 3-4 mins to get max temp on the card, and also noted the min, avg and max FPS plus Max temp, I ran this three times.
Once the defaults were logged, I then set Profile 2 to 800 on the core and set the fan to 55% (just noticable over my case fans). From there I increased the core by 5mhz and ran Furmark stability each time until I reached 825 with no artifacts or lockups etc..
I then set about increasing the mem clocks in 5mhz increments, running Furmark Stability test and Benchmark test each time to note if there were improvements or not.
I wont bore you with All these results from above, as I have a few now
Furmark Settings:
With each profile now set in MSI Afterburner, I used Furmark Benchmark Mode, set to run 3000 frames @1440/900 windowed mode.
CCC Settings:
Vysnc is Off by Default and 4x AA enabled and 8x AF in CCC. I ran the test 3 times for each profile loaded in MSI Afterburner.
The Results: Lowest recorded out of three runs each.
Defaults Clocks: Also saved as profile 1 on MSI Afterburner.
Core: 765
Mem: 1125
Fan: Auto
Min: 109
Avg: 135
Max: 173
Max temp with fan running on Auto = 70
__________________________________
Overclocked Settings: Saved as Profile 2 on MSI Afterburner.
Core: 825
Mem: 1150
Fan: 55%
Min: 125
Avg: 151
Max: 207
Max temp with fan running on 55% = 74, I was Not happy with this temp, so altered the profile to run at 60% while Furmark was still running, temps dropped to 66
_______________________________________________________________________________________________________________________________________
I don't know how much further this card may go, being the Toxic, I cannot alter the voltage, and to be honest, I'm happy to leave it were it is, as its already running plenty fast for the games I play
EDIT: Please see post #8 for update... now running at 850/1200, fan @60.
The Tools:
The Method:
Furmark Settings:
CCC Settings:
Core: 765
Mem: 1125
Fan: Auto
Min: 109
Avg: 135
Max: 173
Core: 825
Mem: 1150
Fan: 55%
Min: 125
Avg: 151
Max: 207
