Talk me out of ditching my Blackberry for an iPhone
I got a slight problem - I got the 9700 now, but I don't have a micro usb cable, can i somehow device switch over bluetooth?
how come you did not get a cable? and if you already have a blackberry can you use that cable? u should have one in the box, go to your local store and demand one!
No you cant but you should have got a micro usb cable with your 9700...was the box sealed and brand new??..if not then id return it and make sure you get a sealed box with everything inside unless you bought it privately and there wasnt meant to be a micro usb cable in it ie person took it out etc.
You can pick them up pretty cheap...i have an extra one that i picked up fro about £2 from the place i got my 9700....use it as an extra cable.
As for device switching via BT??...nope not possible and probably never will be.
Really? I've got Exchange push set up on my work iPhone and the e-mails come through on it before they even hit my desktop. I find it works perfectly.
Of course, enabling push e-mail on an iPhone is a total killer of battery life though.
I have all sorts of issues with exchange and my iPhone. The complete fail that is push email is one thing. (If I turn it on my iPhone is flat by 11:30 without me touching it!)
I also have a number of sub folders on my account which will not poll on the iPhone.
