- 10 Oct 2005
- Nottingham
So, I've been running a DG834N on my Be line for quite a while but it's stability is pretty poor and seems to be getting worse. It hangs/crashes on a fairly regular basis, particularly if wireless in enabled. When it hangs it requires the power to pulled from it twice now, after the first time it just displays a red circle once power is restored.
Googling around this appears to be due to a cooling issue with earlier units and tends to get worse over time until the unit cooks itself.
This has now got to a point where it's irritating enough that I want replace the router with something more reliable.
Needs to have the following:
- Work with Be (ADSL2) .... if it makes any difference I sync at around ~12Mb.
- Have wireless-N support with the usual levels of security.
- Does not need to have a built in switch as it will be connected to a gigabit switch to connect to the wired network
- Needs to be stable when in normal usage (a mixture of the usual things ... not being hammered by torrents the entire time).
N based, D-Link 2740R is your best bet. or if you want to go for price + performance all Netgear higher N class models.
