- 19 May 2005
Our fastest bundle ever, the *OVERCLOCKED* Intel Core i7 980X (Gulftown) 3.33GHz @ 4.00GHz Bundle is now available to order and ready to ship tomorrow. Clocked to a rock solid speed of up to 4.00GHz, this bundle offers amazing performance in the latest games and applications thanks to its 6 cores and new architecture. - ORDER NOW at £1449.99 Inc. VAT.
*OVERCLOCKED* Intel Core i7 980X 3.33GHz @ 4.00GHz Max / Gigabyte GA-X58A-UD7 Intel X58 (Socket 1366) DDR3 Motherboard / Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel Bundle @ £1,449.99 inc VAT
Representing the cream of the crop of today's bleeding edge performance hardware, OcUK's 'Extreme Bundles' are selected to satisfy the needs of the most demanding enthusiast.
OcUK Overclocked Bundles feature carefully selected components tested to assure compatability & stability, guaranteeing the integrity of the overclock.
We worry about the fiddling and tweaking, you just enjoy the performance.
This bundle ships pre-built and pre-overclocked direct from our Technical Department. All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
This Bundle contains the following components:
1 X LATEST! Intel Core i7 980X (Gulftown) 3.33GHz @ 4.00GHz!
1 X Gigabyte GA-X58A-UD7 Intel X58 (Socket 1366) DDR3 Motherboard
1 X Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel DDR3 Memory
1 X Prolimatech Megahalems Performance CPU Cooler
1 X Sharkoon Silent Eagle 1000 120mm Fan
1 X Arctic Cooling MX-3 Thermal Compound
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours.
Note - The bundle operates above manufacturer specifications, as such it requires a quality power supply to operate with guaranteed stability. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range.
Note - Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £1,449.99 inc VAT.
ORDER NOW
- Maximum Speed
- Maximum Stability
ORDER NOW
