configure manual IP address settings for the adapter in Windows.
. Where in windows 7 would I be able to configure this ?That's what I meant by static mappingsDoes your router support DHCP reservations??
That's what I meant by static mappings![]()
.That's something to do with it, in that those are options for the router's DHCP server, but that's just the range of address it dishes out.
Unless your router gives you options to configure static mappings, or whatever Belkin might call them, then you'll need to configure manual IP address settings for the adapter in Windows.
IP address 192.168.1.101 (outside that DHCP range)
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1 (assuming that's the IP address of your router)
turn off dhcp on the router
No it doesn't and it's bad advice. That subnet mask and that DHCP range leaves plenty of other addresses to play with.Will this affect other computers on the network (acsess to internet)..
EDIT: did this and the connection on the other computer broke , does this have to be done?
