Coping software
20 Mar 2004
Need a bit of help tracking down some software.
At work we do a lot of coping of data, from 1 hard drive to another and at the moment we're using a free program called "Unstoppable Copier".
While it seems to do the job, we're a few worrying cases we're it's skipped some data without giving a fault report.
Can any1 recommend me a replacement software?
We don't need clone software, because it most cases we're not coping the entire drive, just sections of it.
You're probably right, I thought maybe the underlying copy process had been improved but if it remains the same that's probably why people don't seem to bother with it!
RichCopy apparantly lacks a few of the features found in Robocopy. These may well have been addressed [been a while since I looked into RichCopy]. In any case they weren't anything vital! :p
For those who use Robocopy, is there any reason why you don't use RichCopy instead? (the supposed replacement)
Personally
I only use the very basic features of robocopy (I only use the /e command, and sometimes I use the log feature)
I use it because it's easier than faffing with xcopy with multiple commands, and I like the report it gives at the end.
So I see no real point in download something extra when 7 can do it straight away and I have my link handy to add it to any XP installs I use.
Stubborness makes me stick with robocopy :)
