- 19 Nov 2008
My mate is going to be building his own pc, I will be giving him a hand.
he will be using it for gaming and be might go dual monitors. he has a max budget of £1000 this will be for case, all internal components and os. he dose not need a monitor as he will get it separately.
he will be going for a 24"monitor so the resolution will be reasonably high(although not included in the budget).
he will want a quad core cpu as he wont be upgrading for a long time.
he is not bothered about ssd.
blueray driver - only spec if there is spair cash as he has one on his laptop already.
I was originally thinking a AMD quad core but looking at benches and peoples revues it seems the i5 is better. so now the main choice is between the i5 750 and the i7 930.
I said it is prob best to hold back and see what the new nvidia series graphic cards are like, even if not as good as ati it is prob worth seeing. (can spec a ati card for now and change it if the nvidia cards are better)
he likes the look of the antec 902 as i have the 900 and he likes the look of that.
thanks for any advise
