I've had my setup running well for the past several months now (see my signature, will add voltages when I get home), but while playing Dragon Age: Origins, I got a BSOD with the "A clock interrupt was not received on a secondary processor within the allocated time interval".
This is the first time I've seen this BSOD and it didn't even happen when I was stress testing using Prime95. Since then, it hasn't happened again while playing Dragon Age, but I was hoping people could give me some advice on tackling this problem if it were to happen again.
So far I have:
1. Cleaned out the dust and checked CPU temps. 40 Celcius idle, 50 under load.
2. Upgraded to latest Nvidia Geforce drivers available.
3. I read this BSOD is related to HT so I upped the Southbridge voltage from normal to +0.1V (1.2V).
Any other setting I should be looking at such as CPU voltages?
Cheers.
So far I have:
Cheers.
